Home » Sponsored » Pi Speakers » Lab 12 push pull sub
Lab 12 push pull sub [message #51971] Thu, 03 April 2008 00:13 Go to next message
Roland Gama is currently offline  Roland Gama
Playing around with Bass Box Pro- A pair of Lab12's modelled in a push-pull sealed enclosure (non-isobaric) gives an spl of about 120db at 800 watts at about 100 hertz and an F3 around 43 hz with a moderately damped enclosure of 2 cubic feet.
How would this system load a room size of 24x24 sq. feet at about 500 watts? Will one do or a pair of the above be necessary for deep punchy and fast bass?
Direct radiating push-pull sub [message #51972 is a reply to message #51971] Thu, 03 April 2008 12:19 Go to previous messageGo to next message
It's definitely a much smaller box. But it also makes much less sound and has higher cutoff. You could make the box a little larger and get lower cutoff. I like that approach. But either way, it's a lot smaller box that is plenty for home hifi use.
12Pi push-pull sub photo [message #51973 is a reply to message #51972] Fri, 04 April 2008 00:08 Go to previous messageGo to next message
Thanks Wayne.
I have completed the 12Pi. Coupled with the 901's it has a huge and thunderous sound stage which stuns everybody into a deafening silence.
Elephant in the house [message #51974 is a reply to message #51973] Fri, 04 April 2008 12:47 Go to previous messageGo to next message
Awesome! I'm amazed you put that basshorn in your house! For some reason, I thought it was for a club.
Don't turn it up loud though, or the next picture you post will be of all the stuff vibrated off the shelves down on the floor.
Re: Elephant in the house [message #51975 is a reply to message #51974] Fri, 04 April 2008 23:55 Go to previous message
VERY VERY TRUE!!!
Previous Topic: Seven mid encloser
Next Topic: final 4pi
Current Time: Sun May 12 19:58:10 CDT 2024
