Home » Sponsored » Pi Speakers » Peizo tweeter use help
Peizo tweeter use help [message #47153] Sun, 19 June 2005 13:55 Go to next message
Mahendra Palesha is currently offline  Mahendra Palesha
Anybody used the 270-082 tweeter for high power PA application. Some people told me that peizo tweeter blow away quickly. I wish to use 270-082 tweeter from parts express. Kindly guide what precaution to take while using the above model tweeter. This model has built in transformer. How it work? Is it better to use crossover, resistor in series or just capacitor. i came to know that along with the transormer there is 4.7ufd condensor is also built in.
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=270-082
PARTS EXPRESS MID/TWEETER HORN DRIVER PIEZO PART NO. 270-082 * Similar to KSN1188A * Built in transformer circuit for increased output and power handling* Power handling: 60 watts RMS/120 watts max * Frequency response: 1,500-20,000 Hz * SPL: 102 dB 2.83V/1m * Mounts to any 1-3/8"-18 TPI horn * Dimensions: Diameter: 4", Depth: 2-1/2".
Re: Piezo tweeter use help [message #47154 is a reply to message #47153] Mon, 20 June 2005 01:09 Go to previous message
Piezo tweeters act like capacitors, so series capacitors act like attenuators, series resistors act like low-pass filters and coils and transformers act like band-pass filters. The circuit you'll use depends on your requirements. They aren't harmed by using them with no crossover at all, so sometimes that's an option.
Previous Topic: 4Pi -> 7Pi Plan, making the 7Pi's shorter
Next Topic: Wayne, can you e-mail me the plans for Studio 2 Pi towers & Stage Pi 4 ?
Current Time: Wed May 01 19:09:46 CDT 2024
