converting port size [message #37824] |
Fri, 16 August 2002 04:45 |
replay
Messages: 284 Registered: May 2009
Grand Master |
hi wayne, i'd like to convert the premium stage 4 pi's port from the rectangular version to a 4" round. can this be done and if so what is the depth? cheers, george
Re: converting port size [message #37839 is a reply to message #37833] |
Fri, 16 August 2002 13:29 |
Messages: 18687 Registered: January 2001
A 6" diameter port would be perfect - Make it 10" long. But the trouble is that you can't fit this port in the cabinet; It's a tight squeeze. Then again, if the compression horn is mounted externally, you might not have any trouble fitting the 6" round port. And I know how you like to put those cool wood horns on top of the cabinets!
