Home » Audio » Group Build » 6A5 P-P # 2
6A5 P-P # 2 [message #32017] Fri, 22 September 2006 21:57 Go to next message
The sockets and a few other bits are mounted, two sets of filament wiring, 12V for the driver.
The drivers are wired up. Normally I build the power supply first but once I mount the power transformer things will start to get heavy…John
Re: 6A5 P-P # 2 [message #32019 is a reply to message #32017] Sat, 23 September 2006 07:42 Go to previous messageGo to next message
Nice work John; what is the driver stage circuit?
Re: 6A5 P-P # 2 [message #32023 is a reply to message #32019] Sat, 23 September 2006 16:10 Go to previous messageGo to next message
Hi M, The driver is an Aikido, Same a line stage with 6SL7 input and 6SN7 drivers. This drives a transformer phase spliter direct to the 6A5’s…John
Re: 6A5 P-P # 2 [message #32029 is a reply to message #32023] Mon, 25 September 2006 11:01 Go to previous messageGo to next message
So then you don't need a pre-amp with it ehh?
Does the 6ug7 have any possiblities in the Aikido do you think?
Re: 6A5 P-P # 2 [message #32032 is a reply to message #32029] Mon, 25 September 2006 17:03 Go to previous messageGo to next message
Hi M,
Although not proven yet, I think I will have enough gain to skip the line stage. I have taken the precaution of installing a volume control
I do not find the 6UG7 in my references. Did you mean the 6U7G?…John
Re: 6A5 P-P # 2 [message #32034 is a reply to message #32032] Mon, 25 September 2006 19:30 Go to previous messageGo to next message
Yes Sorry John. I have a pair of them and Broskie lists them as possible 9 pin driver tubes. Can I ask you; the Aikido; you use the two octals as imput tubes and two as driver tubes for the 6A5's. Can you say a little about how you wire the transformer splitter into that circuit?
Thanks Much.
Re: 6A5 P-P # 2 [message #32035 is a reply to message #32034] Mon, 25 September 2006 21:30 Go to previous message
Hi M,
I think the operative word here is possible. You can use a pentode as the first tube. If you’re set on it but I might start with something like a 12by7 or ecc88(or is it 86?) or 6sj7 in octal. In any case none will work in your board, at least without a bit of redesign. What triodes do you have on hand?
As to the second part. I will post a schematic soon, easier than trying to write about it…John
Previous Topic: 6A5 P-P #3
Next Topic: So; Are we building this thing or what?
Current Time: Thu May 16 07:25:50 CDT 2024
