Home » Audio » Group Build » Say Douglas/813
Say Douglas/813 [message #31120] Thu, 26 May 2005 17:31 Go to next message
Is the GU 13 exactly the same as a 813? Are the russian tubes good? Have you tried this tube yet and was it PP or SE?
Re: Say Douglas/813 [message #31122 is a reply to message #31120] Fri, 27 May 2005 18:22 Go to previous messageGo to next message
Hey-Hey!!!,
I think that GK71 is closest to the 813. not that I have used either yet. I am leaning towards lower voltage filaments. the ratio of filament AC over DC g1 bias looks like an important one to make small...
The 813 is a DH valve with a 10V/5A filament. The Russians did seem to go for 20V filaments for some reason. The 4E27 I am experimenting with is a 5V/7A filament. I think it's a worthwhile valve to play with. I did not turn up any detailed info on the GU13
and now for the SE thing....I have not yet built a SE power stage. No plans to do SE either.
regards,
Douglas
Re: Say Douglas/813 [message #31123 is a reply to message #31122] Fri, 27 May 2005 20:20 Go to previous message
I glanced at a website with a nice SE GU 13 schematic; 6sn7 driver tube using old UTC iron for 20 watts. Really; as long as your experimenting and you have all this parts count and spare Iron; then PP,SE you can have it all.
Previous Topic: DRD 300b set amp
Next Topic: Push-Pull 300B
Current Time: Sat May 18 23:47:28 CDT 2024
