hi. looking for a way to use my fender champion 110, whilst still going through the pa too. there is no line out on this amp so hoping there is a device out there that i can use to solve the problem? thanks for your help!! bob
Wayne Parham Messages: 18686 Registered: January 2001
A lot of people put microphones in front of the amps and run that through their PA. It always seemed weird to me, and it's definitely old school, but that's how they all used to do it. The only other thing you could do would be to modify the amplifier to provide a preamp line level output.
hi wayne thanks for your advise! i've been looking on the internet to see if there was anything i could buy to sort the problem, and found a A/B Y switch. this lets you run one guitar into the input, then split the signal into two outputs. so problem solved. handy little box cos you can switch beween the two outputs,and have two inputs too. thanks again! robert
You need a di box,most have a link output and a balanced line out.Take a jack lead from the box link to your amp and a xlr lead to p.a.this should work ok.
