Home » Audio » Pro Sound » Marshall fade out fuzz
Marshall fade out fuzz [message #27235] Mon, 27 February 2006 11:00 Go to next message
Crackle-Fizz-Bang is currently offline  Crackle-Fizz-Bang
Hi I have a Marshall reverb 12 model (5205) its a 12 watt solid state practice amp. Whilst playing through it and allowing a chord or note to naturally fade away the sound becomes broken up and fuzzy, on the odd occasion the amp has also cut out briefly this happens with either clean or distorted amp settings. Can somebody advise me on what component/s to change, I am familliar with electronic components and soldering but my fault diagnosis is very limited thanks CFB.
Re: Marshall fade out fuzz [message #27238 is a reply to message #27235] Thu, 02 March 2006 13:14 Go to previous messageGo to next message
Huh, it can be many things - from cold solder joint to the faulty component like PS cap. Troubleshooting can be made with some (sinusoidal) input signal, and tracing the fault through the amp, from output to the input. Tech?
Re: Marshall fade out fuzz [message #27239 is a reply to message #27238] Thu, 02 March 2006 14:36 Go to previous message
Hi Damir thanks for your reply, Ive found the root of the problem it was so simple its embbarissing to admit, the speaker has blown.
Previous Topic: Fender Bandmaster Vibrato Problem
Next Topic: marshall valvestate vs65r no sound
Current Time: Sun Jun 02 13:58:29 CDT 2024
