Home » Audio » Speaker » help!
help! [message #15792] Thu, 14 May 2009 19:59 Go to next message
jamin is currently offline  jamin
hi,
loads of
i've been loking to upgrade my current system. its a not very good nad and mordaunt and short setup.
i don't know much about speakers, amps etc. and i don't know anyone who does. i also don't have much time to research or try speakers out. but the best sound i've ever heard came out of funktion 1's so i'm thinking about buying some home sized ones.
the f81's i'm looking at are £780 a pair,
would i want a funktion 1 sub?
if they're not worth it what are the alternatives?
and what kind of amp would i need?
also any other better ideas about a setup for around £2000 would be appreciated
cheers
DIY [message #59266 is a reply to message #15792] Mon, 18 May 2009 10:08 Go to previous message
My suggestion would be to DIY. You can get much better value and sound when building your own speakers. The catch is you have to do some research to build your speakers properly.
Previous Topic: speaker connection missing
Next Topic: finally a system that satisfies!
Current Time: Sat May 04 21:34:38 CDT 2024
