Home » Audio » Speaker » New speakers again...
New speakers again... [message #14997] Tue, 24 May 2005 07:25 Go to next message
Since I put away my EV LS-12 open baffles I've went through a pair of Klipsch Heresys and was using my EV Sx100 pro speakers untill a few days ago. I picked up a pair of old Avid 60 speakers at a garage sale. These are small, thin towers with a 6 x 9 whizzer coned driver run fullrange in a bass reflex box with a small cone tweeter augmenting it (crossed with a 2 uF cap.) They had a bad case of surround foam-rot. Being the cheapskate I am (and a poor beggar to boot), I decided to make my own cloth-roll surrounds. I've done this on several speakers in the past, so I was pretty sure it would work. It did. I've been listening for a couple of days now and must say I got my $6 worth for these.
The 6 x 9 drivers just appear to be common stamped frame drivers of the type that was popular in the late 70's. About a 10 ounce magnet on them. The sound is typical Avid, being taunt and detailed. Not a lot of bass extension, maybe down to 60-70 Hz, making them nice for use with my 12" CV sub. Sensitivity seems to be in the low to mid 90 dB range, but I haven't done any real testing yet to verify this. I'm having to much fun listening to them to bother with testing them. I'll try to get some pics in the next few days. Gotta get back to listening now...
Dave
Re: New speakers again... [message #14998 is a reply to message #14997] Tue, 24 May 2005 07:41 Go to previous messageGo to next message
Dave,
Would you like to expound on how you make cloth roll surrounds? I have a pair of foam surround drivers that will ultimately need new surrounds.
Bob
Re: New speakers again... [message #14999 is a reply to message #14997] Tue, 24 May 2005 07:45 Go to previous messageGo to next message
Do you remember a couple of years ago, there was a guy making the rounds on the internet with his "Worlds Best Speakers" that were just like those? He was going to every audio discussion board plugging his 6x9 speaker in a tower cabinet of some sort. Seems like they were Jensen or Pioneer triaxials or some such thing.
Re: New speakers again... [message #15000 is a reply to message #14999] Tue, 24 May 2005 07:49 Go to previous messageGo to next message
Hi Wayne,
One things for sure, I'd never claim these were the worlds best speakers. However, they "might" just be the worlds best $6 garage sale speakers.
Dave:)
Re: New speakers again... [message #15002 is a reply to message #14998] Tue, 24 May 2005 08:15 Go to previous messageGo to next message
Hi Bob,
I'll try and explain my method of making cloth roll surrounds. It's messy and time consuming, and doesn't look as nice as comercial ones, but it will last almost forever and costs very little.
I use thin cotton sheet material. Cut a series of strips just wide enough to fit from the speaker frame edge to the cone surface to be fastened to. Allow enough for the bend in the surround. All the strips should be as close to the same witdth as you can cut them. Now, remove the gasket on the driver and clean the frame by scraping until all old glue is gone. Carefully scrape old foam off the cone edge. Now, cut small sections about 1/2 to 3/4 inch wide from the cotton strips, cutting them with a slight taper making one end a bit longer then the other. Now, you'll need some silicone sealer and a can of naptha and a small mixing jar (I use a yogert container.) Pour about 1/8 inch of naptha in the cup (use in a well ventallated area with no flames or sparks around.) Sgueeze a bead of silicne into these and stir vigorously for while. What you end up with is very soupy silicone. Lay the speaker on it's back and make sure the voice coil is not rubbing. Apply silicne to both sides of the cloth and rub the cloth. Th idea is to saturate the cloth without adding a build up. Put a bit extra silicone on the cone and frame where the cloth is going and carefully place the large end of the cloth on the frame and the more pointy end on the cone and gently prees the ends down. There should be a roll in the cloth where the origional surround had one. Do the same for the opposite side of the driver. Now come back and repeat this with the next strip just slightly overlapping the first and gently rub the two clothe strips so they seal together. Repeat on the other side. Keep doing this until you get all the way around (this will take awhile.) You'll have to mix new batches of sealer every 15-20 minutes, as it starts to solidify. When the speaker is done and has dried a bit, apply a this coat over the whole surround and make sure there are no openings needing to be glued together. Let dry a few hours and it should work. Glue the gasket back on (I use silicoe, as it sticks to the silicne soaked cloth stips.)
I'd practice this on some dispossable drivers first. It takes a bit of practice to get the cloth just the right size and make everything go together just right.
Let your fingers dry for a half hour or so and the silicone will just peel off like shedding your skin. Much eisier than trying to clean them while wet.
All in all, a messy job to save a few bucks, but is a good alternative for unusual sized drivers. It works well. The surround is very flexible and soft.
Dave
Re: New speakers again... [message #15003 is a reply to message #15000] Tue, 24 May 2005 08:19 Go to previous messageGo to next message
I've actually heard some pretty good coaxial car speakers. Pioneer makes a good sounding little 6x9, to tell the truth. They're tuned to work well in large cabinets, so they sound nice loaded in a trunk, just like they should. The tweeter isn't too bad. Replace the capacitor and you actually have a pretty good speaker. Very workable if you want to improve the sound of an older classic car but keep the original locations of factory installed components.
I just remember the "World Best Speakers" ads all over the place, and thought they were pretty funny. The guy was popping up in discussions about real high end stuff, shilling his car speakers in towers. It was like going to an exclusive jewelry store and having a guy walk up to you with a dozen watches on his arm, selling "Rolex's."
pics of the Avids [message #15005 is a reply to message #14997] Wed, 25 May 2005 09:20 Go to previous messageGo to next message
Here are some pics of the Avid 60 speakers. Scroll to the bottom of the page. There are some close-ups of my homemade surrounds, also.
http://pg.photos.yahoo.com/ph/the_hurdy_gurdyman/album?.dir=6d5d&.src=ph&store=&prodid=&.done=http%3a//pg.photos.yahoo.com/ph/the_hurdy_gurdyman/my_photos
Dave
Re: pics of the Avids [message #15006 is a reply to message #15005] Wed, 25 May 2005 14:11 Go to previous messageGo to next message
Say Mr Hurdy-Gurdy; Scott 299/Thorens TD 160/Heresies. Was that you that bought all my old stuff? I have since moved on but am not so sure I moved up. Why don't you put some of those recordings in the buy site?
Beautiful Husky.
Re: pics of the Avids [message #15007 is a reply to message #15006] Wed, 25 May 2005 17:07 Go to previous messageGo to next message
manualblock,
I don't think I bought any of my old stuff from you. The Heresys came from a local yard sale for $5 (collage girl was selling her boy friend's speakers.) The Scott is a LK-48-b (kit version of a 222D) and was bought from ebay almost three years ago. The Thorens TD-160 costs $3 at another garage sale about 6 or 7 years ago.
Isha appreciates the complement.
Dave:)
Re: pics of the Avids [message #15008 is a reply to message #15007] Wed, 25 May 2005 17:14 Go to previous messageGo to previous message
Oh my, my, my. Those numbers are killing me. You totally scored on a bunch of that stuff, didn't you Dave?!!
Previous Topic: New ESL Research
Next Topic: audax pr 17omo poor driver choice!
Current Time: Wed May 08 13:23:13 CDT 2024
