Home » Sponsored » Pi Speakers » A couple questions about Pi-alignment
Re: Use an image viewer or paint program [message #42574 is a reply to message #42560] Thu, 25 September 2003 22:58 Go to previous messageGo to next message
AR is currently offline  AR
I've used Photoshop and Photodeluxe to try to open and print these pages, but I'm still having trouble with the legibility. I'll keep trying. Thanks.
Re: Use an image viewer or paint program [message #42575 is a reply to message #42574] Fri, 26 September 2003 00:37 Go to previous message
Adobe Photoshop is a great program and so you've got what you need there. I scanned and saved these documents with 2544 x 3299 pixels - a fairly high resolution - so that shouldn't be a problem. Be sure to do a right click on each image, then save the file, and load the saved file into Photoshop. If doing a copy-and-paste, it may be transferring a low-res image rendered by the web browser.
For the most part, each letter is clearly legible although it isn't as clear as a vector or TrueType font. These are bitmaps of a very old scanned document, so the characters will be a bit rough. Still they should be clearly legible for the most part. There may be some places that are more clear than others, so if you find a sentence or formula that is difficult to read, please write to me and I'll try to touch up the image file in that specific spot. But overall, I think you'll find the document is clear enough to read, once you save the files on your computer in the 2544 x 3299 pixel format they are stored as on the server.
Previous Topic: MAF 2005...
Next Topic: Linaeum tweeter - where to find?
Current Time: Sat Apr 27 16:50:55 CDT 2024
