Home » Sponsored » Pi Speakers » 4 pi series/ parallel resistor headache
Re: other problem is no one makes 64 ohm [message #35074 is a reply to message #35073] Sun, 10 February 2002 15:48 Go to previous messageGo to next message
I would hardly nit-pick over a 1 ohm difference in the network. That's just a little over within 5% tolerance which is better then most resistors anyway. It would make no difference at all 17 ohms or 16 ohms. By the way, power handling is increased with parallel resistors but not with series wired ones. You don't get a power handling gain from a series wiring, exactly the same as inductors.
Adam
power handling [message #35075 is a reply to message #35074] Sun, 10 February 2002 16:19 Go to previous messageGo to next message
"You don't get a power handling gain from a series wiring, exactly the same as inductors".
They sure do in the universe where I got my electronics training. Maybe there still is a misunderstanding here. Each part will dissipate power depending on it's share of the load. When building networks using resistors of all identical values, each will be dissipating an equal amount of power, up to it's individual limit, say 12 watts. Each will handle 12, so if 4 resistors, 48 watts. 16 resistors, 192 watts. Sam
Re: power handling: Try this ..... [message #35076 is a reply to message #35075] Sun, 10 February 2002 16:33 Go to previous messageGo to next message
One resistor: Mills non-inductive wire-wound
One cap: Auricap
Of course you need a 2.5watt 2A3 or 300B amp
Re: Us dummies need to stick together! [message #35079 is a reply to message #35070] Mon, 11 February 2002 06:51 Go to previous messageGo to next message
tdc is currently offline  tdc
Danke, Herr Eugenspiel!
Re: power handling [message #35081 is a reply to message #35075] Mon, 11 February 2002 08:54 Go to previous messageGo to next message
I'm curious if I wire two 10 watt resistors in series, how the first one dissipates 10 watts, and then somehow magically manages to transmitt *another* 10 watts through itself so the second resistor can dissipate it. Each resistor will dissipate power in relation to its resistance if wired in series. If four 12 watt resistors are wired in series, the first would have to take 48 watts, the second 36 watts, the third 24 watts and the last one 12 watts for your model to be correct.
Adam
power handling is a [message #35082 is a reply to message #35081] Mon, 11 February 2002 09:38 Go to previous messageGo to next message
function of current. Raise resistance and you lower current. That's why total power handling of the network goes up. Sam
Re: power handling is a [message #35083 is a reply to message #35082] Mon, 11 February 2002 10:40 Go to previous messageGo to next message
I'll take your word for it about the power handling.
Adam
That's Eulenspiegel, Eulenspiegel! Dumkopf!!!!!! (nt) [message #35087 is a reply to message #35079] Mon, 11 February 2002 14:59 Go to previous messageGo to next message
nt
Re: That's Eulenspiegel, Eulenspiegel! Dumkopf!!!!!! (nt) [message #35099 is a reply to message #35087] Tue, 12 February 2002 09:40 Go to previous messageGo to next message
Well, yes and no. Either spelling is used. (See Vienna, Karajan, London 80078 and USSR Symphony, Melodia 40065R which spell it Till Eugenspiel) while other use Till Eulenspiegel. Till lived a very long time ago and spelling may very, he probably couldn't write or spell anyway. But its your moniker take your pick. tdc
And they HUNG me! Ackkkk! (nt) [message #35100 is a reply to message #35099] Tue, 12 February 2002 11:02 Go to previous message
nt
Previous Topic: The Theater 4 Pi's WORK!!!
Next Topic: true readings of power,and false readings
Current Time: Sat May 04 01:54:37 CDT 2024
