Home » Audio » Pro Sound » Hornsub shootout
Re: My impressions [message #28103 is a reply to message #28101] Tue, 18 October 2005 12:00 Go to previous messageGo to next message
The Tuba 24 is definitely a lightweight that packs a heavyweight punch. Small bands can have a couple or four of them, and that makes setup easy.
The heatsink on the 12π doesn't get very hot. It dissipates heat as fast as it sinks it. It feels warm to the touch, but at full power it's only 130º. Without the heat exchanger, motor temperature rises to 195º under the same conditions. At that temperature, the pole piece re-radiates heat back into the voice coil, literally baking it. The glue burns and becomes brittle, and fails to hold the voice coil. When the voice coil comes undone, the speaker begins to buzz as the winding vibrates against the pole piece in the gap. Eventually, the voice coil breaks and the speaker fails entirely. The use of a heat exchanger prevents this. Power levels can be substantially increased, and the motor stays nice and cool so the voice coil glue never fails.
I don't know if you've seen the tests I did on the heat exchanger, but I did a series of temperature measurements. I measured the pole piece at various power levels, with and without the heat exchanger installed. So that kind of lets you know what to expect in terms of longevity.
As for compression due to voice coil heating, the acoustic measurements at the Prosound Shootout shed some light. The sweeps were actually pretty long duration, not gated MLS signals. So they probably heated the voice coil pretty well at high power levels. Compression can be seen as less than 3dB increases between measurements where power was doubled. Each speaker rises 3dB between measurements until it reaches a certain point, where SPL doesn't increase much anymore because compression has set in.
We had planned to do another series of tests that included a lengthy heat soak period, but we simply ran out of time. That would tell us what the speakers acted like after the magnets were very hot. The heat exchanger is really of most benefit in that situation, becaue it prevents the magnet from getting so hot that it re-radiates heat and bakes the voice coil.
Re: My impressions [message #28105 is a reply to message #28103] Tue, 18 October 2005 12:30 Go to previous messageGo to next message
freddyi is currently offline  freddyi
missed all that - every little bit of heat reduction should help. - accidently smoked an Eminence 15 w. 3" coil (9.1mm xmax overhang) with clipped sine and a tiny Servo 260 Samson in a couple of minutes at 20Hz with a tranform EQ box - didn't lock nor open but aroma pouring out of pole-piece then into vent to room smelt pretty nasty - lol
Re: My impressions [message #28106 is a reply to message #28105] Tue, 18 October 2005 12:46 Go to previous messageGo to next message
I know that smell.
Tuba30 [message #28107 is a reply to message #28099] Tue, 18 October 2005 18:17 Go to previous messageGo to next message
PG is currently offline  PG
My Tuba30 didnt make it unfortunately. I wanted to get some measurements, I guess I will have to do them myself. I am thinking of Praxis, any thoughts?
Usage of Zmin [message #28109 is a reply to message #28106] Wed, 19 October 2005 19:52 Go to previous messageGo to next message
Hi wayne.
Why us Zmin used and not some sort of average Z over used bandwidth?
Which is more accurate?
Re: Usage of Zmin [message #28113 is a reply to message #28109] Thu, 20 October 2005 08:33 Go to previous messageGo to next message
The method of impedance determination was one of the things we discussed at the Prosound Shootout. I rarely describe the impedance of a horn being a fixed value because it is too peaky. Instead, I think it's better to look at the impedance curve. So when I wrote the test plan for the shootout, I left final interpretation for each of the participants to agree upon. We made a decision prior to measuring anything, and used the same method consistently for each speaker.
We could use any value as long as it was consistent for all speakers tested and we all agreed. But it's nice to choose a figure that is easy to repeat in other tests and appropriate for comparison with other measured datasets. We didn't have time to accurately determine average impedance using the calculated area under the curve but we could have examined each chart and estimated an average over the 20-100Hz range. We considered using (min+max/2), but this would have given an artificially inflated figure. And we considered using Zmin, which is the most conservative method of all.
In the end, we chose Zmin. It was the most consistent and least subject to interpretation. Of course, using Zmin as the value to determine RMS voltage for test gave the lowest power and SPL. If we had used some sort of average impedance value, the levels would have obviously been higher. It appears to me that using Zmin resulted in choosing voltage levels that correlated very well with expected SPL values. Zmin was David Lee's suggestion, and I think I agree with him that it is probably the best value to use when testing and when considering subwoofer setups, amplifier choices, etc.
Re: Hornsub shootout RESULTS - DR250 [message #28127 is a reply to message #28086] Sat, 29 October 2005 18:09 Go to previous messageGo to next message
Timebomb is currently offline  Timebomb
Hi Wayne, Thanks for posting the graphs, what driver do you use in your DR250? The sensitivity is a little lower than the graph on Bills site, i was just wondering if you useda different driver?
Thanks.
James
Re: Hornsub shootout RESULTS - DR250 [message #28128 is a reply to message #28127] Sun, 30 October 2005 09:54 Go to previous messageGo to next message
You'll have to ask Leland Crooks because those speakers were his. Perhaps he'll chime in on this thread.
Re: Hornsub shootout RESULTS - DR250 [message #28129 is a reply to message #28128] Mon, 31 October 2005 07:54 Go to previous messageGo to next message
Leland Crooks is currently offline  Leland Crooks
I think Bill's figures are with an MCM driver. Mine are with a beta 10. Also my tweeter configuration is not optimal. I have too much spacing between the drivers, leading to comb filtering. (Bill's been getting on me about it since I built them ) That accounts for the spikiness in the upper end. The original plans called for 10, which I built from, but closer together. Since then it has been figured out you can go to 14 piezos in the face, which I plan to do pronto. Will smooth all of that out, increase efficiency, and look cool as hell. When I get it done I'll run some tests with my primitive gear and post it. I don't have a $2k rig like we had at the shootout, but should at least give an indication.
It's an amazing box. Sound guys look askance at it until I fire it up. The sound quality from a $40 woofer and $10 worth of piezos is insane. Along with the volume from only a couple hundred watts. Not an easy build.
Re: Hornsub shootout RESULTS - DR250 [message #28134 is a reply to message #28129] Tue, 08 November 2005 13:41 Go to previous messageGo to previous message
Cheers, would be interested in a seeing a graph with the different tweeter array. Ive built a pair myself with 12 piezos crossfireing and im genrally happy with the sound, though the upper mid could doo with more level i feel.
James
Previous Topic: Basshorn or Transmission Line
Next Topic: Seymour Duncan 84-50 Reverb
Current Time: Sun May 05 08:23:28 CDT 2024
