Home » Audio » Speaker » Midbass slam
Midbass slam [message #83054] Tue, 19 July 2016 06:36 Go to next message
jonone is currently offline  jonone
I went to a house party the other day which was outside and they had hired some pa speakers, they weren't huge probably 12" 2 ways and a pair of 15-18" subs.
The bass was really powerful, that classic hit you in the chest bass just like only live /pa sound seems to be able to create.
Now it got me thinking how my hifi and most other hifi doesn't have this, so why?
My musings are: they obviously use bigger drivers in the midband and there usually high sensitivity, so capable of high spl, which is also an important part of the puzzle, it needs to be loud!
Most hifis in the uk use roughly 6" mid/midbass drivers that are often quite insensitive with low powered amps, so not capable of high spl.
They also sometimes use sub woofers to help the bottem end but there normally crossed over @80hz or below and this is not really where that midbass kick is, so it's still left to the small drivers in the mains to cover the midbass area.
It's interesting to note most hifi and especially AV or obsessed with 20hz and below with huge monster subs were as most pa only goes down to 30hz.
Another part of the puzzle is the room, most pa is used outside or at least used in a space big enough that modes caused by reflected sound is not a problem, but most hifi used in normal rooms will suffer from the reflections caused by the walls and the floor, especially as most have there mid/woofer at ear level, which quite often puts a big notch right where the kick drum energy is.
So the obvious answer is flanking subs to help with the reflections caused by woofer height and position and the mains having large sensitive 10-15" woofers.
The down sides to this are large woofers need large cabs, not very good for waf or small rooms, also they need wide baffles.
my speakers are small active 6" 2 way, the company that makes them feels this is the best compromise, they feel small speakers image better partly because of a small baffle, the theory being the size of the human head is optimal, they also have an exceptable amount of bass and any smaller is an compromise in this area, any bigger and you get crossover problems due to breakup and resonances which again makes the midband an imaging suffer.
They also stick to 2 ways and subs as they feel you get a similar performance as a 3 way without the extra crossover which causes extra distortion and normally ends up right where male voices end, plus subs are more flexible due to adjustable volume and positioning.
They also use active for less distortion and the ability to use steep filters so any nastys in the drivers are well out of audible range.
They are rated at 108db according to the manufacture.
The cons of a 6" 2 way playing full range is intermod distortion but this is arguably not audible and according to the manufacturer to counter act this you would have to cross over at something like 100hz or above resulting is less bass sources for the multi sub technique.
Also the flanking subs are feed the same signal as the mains so if you high pass them the flanking subs receive the same high passed signal resulting in fewer deep bass sources.
The pros are better for waf/smaller rooms and arguably a better mid range.
Subs are easier to hide, my two 15" flanking subs in down firing cubes will arguably look at lot smaller and less "hifi" then 15" speakers with 17+"' front baffles but I suppose this depends on taste and room size.
So my setup will be, 6" active 2 ways as mains playing full range with two 15" stereo flanking subs which are low distortion, they will be crossed over high enough to play in the the midbass area and with 18mm Xmax they are useful as deep bass sources too.
I will also have a single near field sub fed from the lfe output of my AV receiver.
I'm hoping with the smoother response from multiple bass sources and two 15s playing in the midbass I can get some of that slam! Cool
I would love to hear your opinions especially big vs small speakers.
Re: Midbass slam [message #83055 is a reply to message #83054] Tue, 19 July 2016 15:25 Go to previous messageGo to next message
If your subs integrate well with your tiny mains, I think you may be fine.
In my past experience, I had a hard time doing that-
Around 3 years ago, I built/owned a typical hifi set of speakers with dual scan speak 6" woofers per cabinet-
https://www.madisoundspeakerstore.com/3-way-speaker-kits/b741-scan-speak-kit-pair-by-peter-noerbaek/
They are about 88db sensitivity.
After an intensive, difficult buid (I attribute most of this to the tapered baffle) I gave them months of listening time.
I ended up feeling very dissapointed in the lack of mid-bass punch, no matter how loud.
They just sounded kind of flat, and unexciting.
I decided (it was suggested) to built a sub to try an help.
The end result was the same good mid range and great high end from the mains, with added extreme low end from the sub, yet no more mid bass slam.
What didn't help with the punch, is I had to low pass the sub at 50hz, because it simply wouldnt integrate well with the mains anywhere above that,
regardless of position.
I then did extensive room treatments (bass traps, large broad band absorption).
Bass response improved, but still no mid bass punch to speak of, sort of a hole right in the mid bass.
Thats when I decided to try a pair of high sensitivity speakers (4pi's).
The first two things I noticed, was more midbass punch and more dynamics.
After some time of liking these mains much more than my previous pair, I decided to try a S.E.T. tube amp with them, having heard that this type of amplification was a great combination with high sensitivity mains.
End result is, this current system smokes my last one, the punch, dynamics and most surprising to me.......the mid-range. This is all "without" subs.
This current system, using high sensitivity mains, does not have the mid bass slam of an outdoor system as you describe, but it sure has more punch than my previous set of speakers had!
I am about to add a pair of 3pi's, which Im sure will bring it closer, as that is what they are designed for.
In regards to your mains, it is hard to believe your two way, 6" speakers are really 108db 1w/1m or even close to that.
Are they horn loaded?
I installed quality cherry wood veneer on my 4pi's, with matching front grill covers, and most people do not even notice them when they enter our living room.
They simply look like the rest of the front furniture.
I am building the 3pi subs the same way.
Youd be surprised what you can get away with in your living space,
when the speakers no longer look like big (or small) black boxes.
Regards!
Re: Midbass slam [message #83056 is a reply to message #83054] Tue, 19 July 2016 17:05 Go to previous messageGo to next message
Thanks for the input, I'm glad your beginning to see success with your system!
And your right using veeners and matching other furniture goes a long way to integrating into your home.
As for the 108db, I do take it with a pinch of salt, although the md of the brand swears it so, I've seen others work out the maths for them and not come to the same conclusion.....
What I will say is they are loud, certainly plenty loud enough for a living space.
Re: Midbass slam [message #83057 is a reply to message #83054] Tue, 19 July 2016 17:06 Go to previous messageGo to next message
http://www.avihifi.co.uk/products.html#
No there not horn loaded.
Re: Midbass slam [message #83081 is a reply to message #83054] Mon, 25 July 2016 17:43 Go to previous messageGo to next message
Jonone.
Have you been listening to your system with the new set-up, with your flanking 15's?
If so, how is it sounding so far?
I have not finished my 3pi sub enclosures yet.
Re: Midbass slam [message #83093 is a reply to message #83054] Tue, 26 July 2016 01:18 Go to previous messageGo to next message
Nope still just got the one midbass up front and a nearfield sub at the moment, i have been talking to acoustic elegance about making me another driver for another midbass.
It's all been put on hold though as we have just had another baby......
At some point I'm going to try and put the nearfield sub in the flanking sub position and see what it's like.
I am planning on ordering another driver from ae regardless as I will want to run this configuration in the future.
Re: Midbass slam [message #83094 is a reply to message #83054] Tue, 26 July 2016 05:14 Go to previous messageGo to next message
Let us know.
Congrats on the new baby!
Re: Midbass slam [message #83095 is a reply to message #83094] Tue, 26 July 2016 06:03 Go to previous messageGo to next message
Thank you.
I will let you know what happens with the flanking subs!
Good luck in building yours, post up some pictures! Have you got any pictures of your setup at the moment?
Re: Midbass slam [message #83097 is a reply to message #83095] Tue, 26 July 2016 06:30 Go to previous messageGo to next message
Sounds great.
I'll get some pics posted of my current setup, when I get home from work.
Re: Midbass slam [message #83100 is a reply to message #83054] Tue, 26 July 2016 15:06 Go to previous messageGo to previous message
Here is my current set up.
It sits along the front/narrow wall (15.5').
Front door is on the left.
When I incorporate the flanking subs, I will have to re-locate the
speakers and tv along one of the long/side walls (27').
I will also be able to angle (toe in) the mains for better stereo image for all in the room.
I know firing the speakers from the longer wall is not best, but it's the only way I can utilize the flanking subs until I move everything downstairs.
index.php?t=getfile&id=1943&private=0index.php?t=getfile&id=1942&private=0index.php?t=getfile&id=1941&private=0
  • Attachment: image.jpeg
    (Size: 1.59MB, Downloaded 2643 times)
    (Size: 1.66MB, Downloaded 2712 times)
    (Size: 1.04MB, Downloaded 2518 times)
Previous Topic: Wireless speakers vs wired
Next Topic: Is stereo a misunderstood logic?
Current Time: Sun Apr 28 10:15:15 CDT 2024
