Home » Sponsored » Pi Speakers » 4pi's on the way!
Re: 4pi's on the way! [message #76906 is a reply to message #76706] Sat, 01 June 2013 18:21 Go to previous messageGo to next message
Ash R is currently offline  Ash R
My woodworker sent a snapshot of his progress =>
index.php?t=getfile&id=1182&private=0
I am so pleased to be finally getting these done. They are the real deal, often imitated but never duplicated. Razz
Re: 4pi's on the way! [message #76910 is a reply to message #76906] Sun, 02 June 2013 01:19 Go to previous messageGo to next message
Nelson Bass
Looks stunning good!
The bracing attached to the sides is that a third one additional to the original design?
See this thread: http://audioroundtable.com/forum/index.php?t=msg&&th=15168&goto=63679#msg_63679
Re: 4pi's on the way! [message #76911 is a reply to message #76910] Sun, 02 June 2013 01:30 Go to previous messageGo to next message
It does look a little lower than most people put it, but as long as the front-back brace is in there between woofer and tweeter and the side-to-side brace doesn't interfere with the woofer, it's fine. Just make sure to install the cross-section damping material between woofer and tweeter.
Re: 4pi's on the way! [message #76912 is a reply to message #76911] Sun, 02 June 2013 09:15 Go to previous messageGo to next message
Didn't Scott contact you about the braces? He asked me about them and I told him to email you directly.
Re: 4pi's on the way! [message #76918 is a reply to message #76912] Sun, 02 June 2013 20:59 Go to previous messageGo to next message
Yes, Scott wrote to me asking if the front/back brace needed to be connected to the side/side brace. I replied essentially the same thing I wrote in my last post, that they could be separated a little bit, provided there was no interference with the woofer or tweeter and the sheet of insulation spanning the cross-section could be easily installed and supported by the brace.
Re: 4pi's on the way! [message #76928 is a reply to message #76918] Mon, 03 June 2013 10:47 Go to previous message
Ok great, that's how they are. Thanks!!
Previous Topic: Coax in horn
Next Topic: compare 3pi vs Klipsch Synergy F2
Current Time: Wed May 08 05:33:41 CDT 2024
