Home » Sponsored » Pi Speakers » Pi Sevens up and running!
Pi Sevens up and running! [message #51315] Tue, 07 August 2007 12:46 Go to next message
Tim Barnes is currently offline  Tim Barnes
At the weekend I finally was able to install my new Pi Sevens in my living room. Here's a first set of impressions.
My system is as follows:
* Townshend Rock III turntable with Grado MM cardtridge.
* EAR 834P phono stage
* Naim CDP8i CD player
* First Sound passive "preamp"
* Music Reference RM9 tube amplifier
* Mixed cables - DIY solid silver, Cardas speaker cables
The speakers replace my Thiel CS3.6 floor-standers, in roughly the same locations (corners). The room is sub-optimal in that the speakers are in corners that also house bookcases, and there's a baby grand piano between the speakers along the same wall. However, there's no sign yet of any piano-contributed vibration.
I've been listening to lots of stuff: Beatles, Tom Paxton, King's Singers, Lieder (Brahms, Schubert), Wagner, Gilbert & Sullivan, Dave Brubeck, and a mix of CDs and records.
The first impression is of a very delicate and accurate mid-range. The King's Singers have never sounded better. The mid-horns seem solid and unfussy. The treble is clear, but I think a bit recessed, and definitely less audible than with the Thiels. The bass I'm not quite sure about yet. Clearly the power of the woofer is exciting a couple of room modes, and I will need to build some tube traps or something, and possibly alter the room layout a bit (I'm sitting against the back wall, which is probably not ideal). The most obvious effect is on plucked bass lines, and also some coloration on male voices. But except for the notes that are too loud, the bass seems clear and unobtrusive. I don't know if I'm really getting all the extension I was expecting - this may be because of the bookcases, or (and I hope not) it's possible the cabinets leak. I have been unable to detect much port action so far.
The other major change is the increased level of dynamics. I find I have to adjust the volume for every recording separately - I never needed to do that before. Popular recordings with lots of compression need to be turned well down. Classical recordings with wide dynamic range can be turned up and I still get good pianissimo, with exciting climaxes. The bass excitation limits my ability to listen loud - especially with bass or baritone voices.
I should mention my long-suffering wife's responses - she has three (presented in unvarnished form):
1. "They are bigger than you led me to believe"
2. "They are uglier than I thought"
3. "They sound much better than the old speakers."
...so I guess I get to keep them, but I will need to finish the veneering and clean up the wiring etc.
So once again, Wayne - thanks for all your support through the process, and thanks for the design. The project was worthwhile, and has given my music collection a new lease of life. I look forward to more projects - office and garage speakers, and perhaps some room acoustics modifications.
Regards,
tim
Re: Pi Sevens up and running! [message #51320 is a reply to message #51315] Wed, 08 August 2007 09:33 Go to previous messageGo to next message
That's awesome, Tim! Thanks for posting.
Check room wall and bookshelf panels for sympathetic vibrations. This is one of the most troublesome issues I find. Shelves sometimes buzz, and cabinets with closing doors sometimes vibrate door against stop. Do something to preload the panels that make your shelves back walls and see if you can find ones that are making noise. Chances are, you'll find a lot of things in your home that buzz when vibrated. The different woofers and setup may energize them differently and make it more noticeable.
Re: Pi Sevens up and running! [message #51327 is a reply to message #51320] Wed, 08 August 2007 11:47 Go to previous messageGo to next message
Thanks for your thoughts. The bookshelves are built-in and pretty solid, but I'll have a close look at them.
Last night I "installed" four bags of R19 insulation under the piano and in corners. The bass boom is gone, but the treble is now definitely too light, so I've overdone it a bit. I'll keep on experimenting and I plan to take some measurements over the weekend.
The most obvious problem I can detect at present is that the front of the bass cab vibrates a bit, despite two glued-on braces and two cross-braces (above and below the woofer).
Would it be a good idea to put in some kind of compressible bracing between the back of the woofer and the front of the cab? Or should I just add more glued-on pieces to the inside of the front?
Re: Pi Sevens up and running! [message #51329 is a reply to message #51327] Wed, 08 August 2007 12:26 Go to previous messageGo to next message
I would suggest running braces along the front. Glue 1x2 wood along the panel with the taller dimension (2") standing up. That way it will resist panel flex.
If you find room modes are troublesome, you may want to add a couple subwoofers. This may seem counterintuitive, especially if you feel that the bass is strong. But what will happen is bass will be made more smooth as a result. Use CARA and figure out where to place the subs. I have found many cases where the four opposing corners are best, and others where they're not. Of course, your decor will determine what you have to work with too.
I usually suggest the additional woofers be the same as the ones in your sevens. They don't have to be cornerhorns, but they surely can be. If not cornerhorns (with mids and tweeters), then low-pass them very low, below 100Hz. This prevents localization and improves integration, by keeping sound sources acoustically close. Or you can go with a different approach, using woofers like the LAB12 that are tuned for a very deep range. This lets you hit even deeper bass notes while providing smoothing of the overlapping range. You may be able to install subs in cabinets that fit under existing furniture. You can usually find a configuration that models well in CARA and that also fits in nicely with your room decor.
Re: And what does wifey think of the R-19? [message #51330 is a reply to message #51329] Wed, 08 August 2007 18:29 Go to previous messageGo to next message
IRS is currently offline  IRS
Or adding 2 or 3 more sub-woofers. LOL.
I've got 3 stacks (John Risch cheap 'n dirty bass traps) of R-13 fiberglass that comes in rolls in corners.
That tamed the bass boom in my room: poorly suspended wood floor.
I cut plywood circles for the tops of the stacks and stapled colored burlap to the edges which skirt the rolls down to the floor. Kat likes to sit on the one by the window. After she bakes you a pie you might let the little woman choose the fabric herself.
The thicker the insulation the lower the frequencies absorbed so
your R-13 shouldn't be lightening the treble. Just the opposite. There should be more clarity. I think you're hearing the lesser extension of a horn tweeter compared to your Thiels. Might want to consider a JBL 2405 or other super-tweeter.
Just my buck and a quarter.
Easy to add Post-assembly Bracing [message #51331 is a reply to message #51327] Thu, 09 August 2007 11:04 Go to previous messageGo to next message
I've used 1" 'dowels' several times -- available from Home
Depot. Cut them to length, see if you can straighten them
into position, if not sand the ends slightly and try again.
Once you have a fit, take them out, smear glue on both sides
and put them back. Once you see/feel what's vibrating, you
get a pretty good idea about where to put them.
Skip
Room treatments [message #51332 is a reply to message #51330] Thu, 09 August 2007 13:24 Go to previous messageGo to next message
Raised hardwood floors are almost always problematic. Their acoustic contribution is usually even worse than room modes, because they tend to form a resonant chamber, like a large bass drum. You really have two sets of room modes to deal with when setting up a sound system in a room having a suspended wood floor. You have the modes of the crawlspace, which are generally severe, and you also have the modes of the listening room. The room itself may be reasonably well damped, but the crawlspace usually isn't. The ground and supporting side walls are rigid, but the floor vibrates. This makes a perfect resonator with very little damping - an acoustics nightmare.
Rooms without raised hardwood floors are usually better. However, if the walls are rigid, then modes aren't well damped. Rooms with rock, concrete or brick walls usually have more modal problems than those with framed drywall construction. Rooms like these can benefit from bass trap panels. Sometimes, things in the room act as resonators, and that causes problems too. Built-in cabinets sometimes resonate or buzz. Large free-standing furniture sometimes resonates. So there are lots of things to look out for.
Re: Hardwood floor [message #51333 is a reply to message #51332] Thu, 09 August 2007 18:09 Go to previous messageGo to next message
My floor may be marginally better than some - it's an engineered hardwood floor (basically plywood planks) laid on a few mm of foam, over a particle board floor on joists (I used to have carpet). I also have a big rug in the middle of the room and quite a lot of soft furniture.
But in any case, I'll see what it sounds like under the floor. I imagine that if I use Cara to work out room modes, and then when I measure I find something different, it may be because of the sub-floor space?
I have some other things to do as well - explore moving the piano to another part of the room to let the horns do their thing with fewer obstructions; put some kind of absorbent pad under the piano (a Jon Risch-style trap lying on the floor?); and then we'll see where I am.
The room needs to get back to the clean and minimalist look it had before I put all the stuff in there - it is meant to be a peaceful place, not just a listening room...
Re: Super-tweeter [message #51334 is a reply to message #51330] Thu, 09 August 2007 18:13 Go to previous messageGo to next message
I would like to experiment with a supertweeter, but I would rather not spend too much until I have proved the concept.
Any suggestions in the sub-$100 range?
Re: Easy to add Post-assembly Bracing [message #51335 is a reply to message #51331] Thu, 09 August 2007 18:15 Go to previous messageGo to previous message
That will work well for face-to-face braces. Is it a good idea to brace against the back of the woofer?
Previous Topic: JBL 2416
Next Topic: what design can i throw 8 jbl 2206J's in?
Current Time: Mon May 20 10:01:55 CDT 2024
