Home » Audio » Speaker » Controversy on tweeter's positioning
Re: Thanks for asking good questions [message #24316 is a reply to message #24313] Mon, 05 May 2008 20:04 Go to previous messageGo to next message
Danny Richie is currently offline  Danny Richie
If it were me, I'd put more money into the electronics and use passive networks on the speakers.
Re: In simple terms [message #24354 is a reply to message #24305] Wed, 14 May 2008 20:31 Go to previous message
Rick Craig is currently offline  Rick Craig
JPH,
The delay function allows you to keep the drivers in phase because the time arrivals are different for the ribbons versus the woofers. The Behringer was designed for pro audio applications where this is very important; otherwise, the sound won't be coherent at the listening position. As far as your issues with vocals it could affect that but without being there I can only speculate.
The amount of delay used will also vary depending on whether you measure with the ribbons on the inside or outside. A lower crossover point doesn't change things because the arrival time between the two drivers remains the same. One advantage of your active crossover is that it doesn't add any inductive or capacative phase shift like a passive crossover will.
Previous Topic: So I went ahead and built them. . .
Next Topic: Hey Guys, Where Do We Want to Take this Forum?
Current Time: Sun Jun 02 06:31:22 CDT 2024
