Home » xyzzy » Tower » Jesus;Mary and Joseph; will he never go home!
Re: Jesus; Mary and Joseph; will he never go home! [message #54053 is a reply to message #54052] Mon, 02 August 2004 15:59 Go to previous messageGo to next message
I think probably the B+ plate supply is diode rectified and then filtered with a resistor, cap and coil. That's pretty basic stuff. The cathode filaments are probably driven by a separate transformer winding that provides low voltage AC.
Re: Jesus; Mary and Joseph; will he never go home! [message #54054 is a reply to message #54053] Mon, 02 August 2004 17:05 Go to previous messageGo to next message
Thats exactly right, except the filament winding of the power tranny provides for a seperate bridge rectified pi filter to the 300b's and a seperate winding to the driver tubes.
Re: Jesus; Mary and Joseph; will he never go home! [message #54055 is a reply to message #54054] Mon, 02 August 2004 17:36 Go to previous messageGo to next message
Let me see if I understand you about the DRD amp:
1. The filament on the 300B is driven with DC. It comes from a transformer winding that is rectified and filtered.
2. The driver tube heaters are driven with AC that comes from a different transformer winding than the 300B filament supply.
Is that right? Do you happen to know the filament voltages for each tube? Do you know the plate voltages? Is there a single rectifier for B+ for all tubes?
Re: Jesus; Mary and Joseph; will he never go home! [message #54056 is a reply to message #54055] Tue, 03 August 2004 07:09 Go to previous messageGo to next message
Yes they have A center tapped secondary that provides 700V for B+;
Then the there is 6.3v 1a AC secondary for the filaments of the driver tubes and then they have 7.2V 2a filament winding that is rectified by a 4a 50 piv bridge into a pi filter for 5vdc for the 300b's. B+ is connected at the primary. The plate voltages would be fairly simple to figure mathemagectly but it takes me some time. There is not much more to the circuit.
Re: Jesus; Mary and Joseph; will he never go home! [message #54057 is a reply to message #54056] Tue, 03 August 2004 12:14 Go to previous messageGo to next message
Is the 300B filament supply the one that is sometimes too high?
Re: Jesus; Mary and Joseph; will he never go home! [message #54058 is a reply to message #54057] Tue, 03 August 2004 12:18 Go to previous messageGo to next message
You know what; they have provision in the schematic for a trimmer resistor adjustable to 5v for the 300b fil supply. I can't say for sure since the posts were deleted but can you tell if that would account for the issue at hand?
Re: Jesus; Mary and Joseph; will he never go home! [message #54059 is a reply to message #54058] Tue, 03 August 2004 12:58 Go to previous messageGo to next message
Yeah, I'm thinking that's probably it. If the transformer secondary is supposed to provide 7.2V, then the peak value is about 10V. A lightly loaded supply could rise to almost double the intended 5 volts.
Re: Jesus; Mary and Joseph; will he never go home! [message #54060 is a reply to message #54059] Tue, 03 August 2004 14:46 Go to previous messageGo to next message
I notice there are huge cap. values on the fil. supply filter, 10000uf. Is that usual?
Re: Jesus; Mary and Joseph; will he never go home! [message #54061 is a reply to message #54060] Tue, 03 August 2004 23:02 Go to previous message
The bigger the cap, the more energy it can store. The more current is required, the larger the cap must be to reduce AC ripple.
Previous Topic: PayPal Class Action Settlement
Next Topic: Ever wonder why?
Current Time: Thu May 23 00:49:19 CDT 2024
