Home » Audio » Pro Sound » do karlson do anything well?
do karlson do anything well? [message #28108] Wed, 19 October 2005 18:32 Go to next message
freddyi is currently offline  freddyi
controversial - guess worse case = "look cool"
looking at pi's fab horn shootout am sometimes confused with regards to harmonic disortion figures as can only look at one or two tones.
a simple 8cu.ft. Karlson box here will look better below passband (and perhaps inside the band) than my UCS1 or a Z-fold JBL sub.
here's 30vrms/50Hz into a simple karlson w. old Eminence 18 without front shelf which corrects 1st dip (somewhat) guess nominal would be ~150w by z-minimum critera - IIRC fb was around 42hz with two 4"x4.5" pvc ducts
smoke? not in a few seconds!
lower level sine UCS1 vs karlson UCS1 had 15dB more 3rd harmonic than the karlson. UCS1 has a fairly high input Z
one sheet klam w. 3cu.ft. rear chamber is it ~BP4
karlson are odd things with regards to initial slot gap and flare - if gets clogged by an inch then sounds 10X worse run wideband. might be possible to squeak a bit more performance within a givin bulk by going taller and should be looked at by 3rd Z peak to compare to bandpass boxes for similarities.
added some height to a test box but affair was too rickety to judge. crazy part - when running an 18" wideband a very narrow slit in the extension running up to very top allowed it to play better including the sense of HF - doubt if would show on RTA - be like that dumbass show with guy lookin' for ghosts with a $10 multimeter.
k are reasonably simple and light - if using cheap birch - lol -whether have place in pa - dunno - I'd use one but am stubborn.
Freddy
Re: do karlson do anything well? [message #28111 is a reply to message #28108] Thu, 20 October 2005 08:13 Go to previous messageGo to next message
We've gotta get one of those Karlson cabs out at the next Prosound Shootout! There's also a hifi event in May (GPAF), maybe someone will bring one to that.
Re: do karlson do anything well? [message #28115 is a reply to message #28111] Thu, 20 October 2005 08:52 Go to previous messageGo to next message
I'll try getting one out for GPAF there pretty easy to build besides I think I have some old plywood, not birch the cheap stuff, to build 1 or 2 to experiment with.
Bill W.
Re: do karlson do anything well? [message #28119 is a reply to message #28115] Thu, 20 October 2005 09:38 Go to previous message
Sounds great, Bill. And thanks again for all your help with the 12π and the Prosound Shootout.
Previous Topic: Floor Pocket Problems
Next Topic: Eminence driver that can handle 1250 wattts RMS, with heat sink
Current Time: Thu May 23 07:35:53 CDT 2024
