Home » Audio » Pro Sound » Lab Horn
Lab Horn [message #28037] Fri, 04 February 2005 00:30 Go to next message
Quiet Storm is currently offline  Quiet Storm
Does anyone have a design using single lab horns? I am very interested in using a pair of these, but not with two in each box. Cost and weight are serious factors here. I love the idea of a folded horn and these speakers look like they go pretty low. Thanks for any responses.
Re: Lab Horn [message #28038 is a reply to message #28037] Fri, 04 February 2005 09:30 Go to previous messageGo to next message
Check the Fitzmaurice forum - He does prosound horns with single woofers. I think Mike E. (toxicport) has plans for a horn using a single LAB12 too.
Thanks. [message #28039 is a reply to message #28038] Fri, 04 February 2005 13:26 Go to previous messageGo to next message
Thanks. Looks like something from there will work.
Re: Thanks. [message #28041 is a reply to message #28039] Thu, 07 April 2005 16:53 Go to previous messageGo to next message
Disco Stu is currently offline  Disco Stu
There are a few options the lab driver isnt that great used on its own. Try looking here for a design utilising the lab http://photofile.ru/default/do.php?id=3426459#sm
There is also the punisher for a 12" ciare driver http://www.iven.nl/kastontwerpen/punisher.htm
Other than that the Tuba 30 on bills forum is for a 12" not the lab driver tho!
Re: Thanks. [message #28042 is a reply to message #28041] Thu, 07 April 2005 18:38 Go to previous message
The LAB12 driver makes an excellent bass-reflex subwoofer in a 2.0ft3 to 5.0ft3 cabinet tuned to 20Hz. When you consider that output in the bottom octave of all the popular subs is direct radiation anyway, it makes a lot of sense for hifi use. But for prosound above 40Hz, a folded horn will obviously provide more output.
Previous Topic: Using a bass amp for electric guitar.
Next Topic: Vox Pathfinder Repair
Current Time: Tue Jun 04 17:11:34 CDT 2024
