Home » Audio » Source » Need Cartridge or Needle for Miracord 50H
Need Cartridge or Needle for Miracord 50H [message #13162] Sun, 19 November 2006 14:20 Go to next message
david is currently offline  david
I have a Miracord 50H with a Shure V15 Type II cartridge. During a move, the needle got bent. I am looking for a replacement needle or cartridge. Will a Shure M97xE fit? If so, is it a reasonable replacement for a reasonable price? I'm not looking for a very expensive solution if a reasonably priced one will do the job. If it sounds anything like the Shure V15 did, I will be happy with it.
Thanks for your help.
David
Re: Need Cartridge or Needle for Miracord 50H [message #13175 is a reply to message #13162] Sun, 26 November 2006 12:16 Go to previous message
I'd give the guys at NeedleDoctor.com a call. They can probably fix you up. Check out the replacement charts they have available online too.
Previous Topic: Pro-Ject turntables
Next Topic: my technics sl-1900 doesnt work in 45
Current Time: Wed Jun 10 01:41:13 CDT 2026
