Home » Audio » General » USB Cable with Separate Audio & Power
USB Cable with Separate Audio & Power [message #76483] Thu, 25 April 2013 06:45 Go to next message
This USB cable by KingRex is a Y-type, with power going to one end and the audio going to the other. I wonder how much of an advantage you get by the separation; all I can see right now is needing two USB ports instead of one.
Re: USB Cable with Separate Audio & Power [message #76502 is a reply to message #76483] Thu, 25 April 2013 21:10 Go to previous messageGo to next message
Hi, There are a number of possible advantages. Lots of time the power from the PC or laptop is full of junk. Using and external power source can provide clean power and improve the sound. Also you can get more power from an external power source than is available from the computer. The computer is usually limited to providing 500ma max. External sources I have seen can do as much as 2 amps.
Re: USB Cable with Separate Audio & Power [message #76524 is a reply to message #76483] Fri, 26 April 2013 21:23 Go to previous message
Yes. Gofar is right. More power that is cleaner is the main advantage. If you are into the quality sound as much as I am, it is well worth it.
Previous Topic: Annoying Rattling Sound?
Next Topic: Re-mastered vs. Original
Current Time: Thu May 23 02:46:58 CDT 2024
