Home » Sponsored » Pi Speakers » Flush mount (drivers)
Flush mount [message #69819] Sun, 16 October 2011 20:04 Go to next message
Dpend is currently offline  Dpend
Is it necessary to flush mount the drivers in the towers
Re: Flush mount [message #69822 is a reply to message #69819] Sun, 16 October 2011 23:16 Go to previous messageGo to next message
No, it's done purely for aesthetics. Some flush mount, others surface mount.
Re: Flush mount [message #69824] Mon, 17 October 2011 10:30 Go to previous messageGo to next message
What about gaskits between the driver and wood are they needed
Re: Flush mount [message #69825 is a reply to message #69824] Mon, 17 October 2011 12:47 Go to previous messageGo to next message
The woofer has a built-in gasket. The tweeter doesn't. If the wood is very flat and true, then no gasket is really needed but it never hurts to use one. You can make one from thin cardboard or PVC.
Re: Flush mount [message #69827 is a reply to message #69825] Mon, 17 October 2011 19:34 Go to previous messageGo to next message
Thanks
Can you tell me if you have an order from me?
Re: Flush mount [message #69828 is a reply to message #69827] Mon, 17 October 2011 21:50 Go to previous messageGo to next message
No, sorry. I think you said you mailed an order in, yes? It hasn't arrived yet. We'll email a confirmation once it comes.
Re: Flush mount [message #70574 is a reply to message #69825] Thu, 22 December 2011 14:28 Go to previous messageGo to next message
Wayne,
You had a link showing how to make gaskets from 40 mil thick plastic. Where do you buy plastic like that?
Floyd
Re: Flush mount [message #70578 is a reply to message #70574] Thu, 22 December 2011 19:14 Go to previous message
You can find it at most hardware stores as shower pan material.
They don't use lead anymore for shower pans, they use this stuff.
Previous Topic: Dpend
Next Topic: 8 Pi Crossover questions
Current Time: Tue Jun 09 13:13:42 CDT 2026
