Home » Sponsored » Pi Speakers » 8 pi plans
8 pi plans [message #61795] Mon, 01 February 2010 21:10 Go to next message
disaacso is currently offline  disaacso
been looking around hear for a while for a project. Think I'd like to try the 8pi's. I would appreciate it if i could have the plans for the enclosure and crossover for the 8pi's.
also as a secondary question, just to satisfy my curiosity, can a corner horn like the 7pi be mounted above floor level. I have radiators running the length of every wall so to use a speaker like this it would need to be mounted above.
Thanks
Dan
Re: 8 pi plans [message #61796 is a reply to message #61795] Mon, 01 February 2010 23:19 Go to previous messageGo to next message
You've got mail!
The problem with mounting the cornerhorn off the ground is the midhorn and tweeter would be unnaturally high. It was designed to be placed on the ground, but except for the height of the HF drivers, you could lift the cabinets, especially if you were using multiple bass sound sources. Maybe invert the cabinet, hanging the midhorn and tweeter below the bass bin.
Re: 8 pi plans [message #62142 is a reply to message #61796] Sat, 20 March 2010 13:57 Go to previous messageGo to next message
tymek is currently offline  tymek
Hello. I can get plans for switch box and the crossover 8 pi. The address damdu7@o2.pl
Re: 8 pi plans [message #62143 is a reply to message #62142] Sat, 20 March 2010 14:04 Go to previous messageGo to next message
Polish mounted tweeter speaker intend to
http://www.allegro.pl/item953111016_tonsil_gdwt_9_80_5f_fabrycznie_nowe_gwar_12_m.html
Re: 8 pi plans [message #62145 is a reply to message #62143] Sun, 21 March 2010 10:24 Go to previous messageGo to next message
You've got mail!
The drivers used in this design are listed in the plans.
Re: 8 pi plans [message #62210 is a reply to message #61795] Sun, 28 March 2010 23:27 Go to previous messageGo to next message
lunkie is currently offline  lunkie
Wayne, how would the Alpha 10 work if it was installed in your mid range horn? The horn section itself in the 8pi looks the same? I would have to build a rear chamber for it? I'm not concerned with a crossover network as I use a low level active network.
Lunk and the Low Notes
Re: 8 pi plans [message #62211 is a reply to message #62210] Sun, 28 March 2010 23:30 Go to previous messageGo to next message
The Alpha 10 actually works pretty well in the midhorn. It doesn't have quite as much power handling capacity as the Delta 10, but it works well and sounds nice.
Re: 8 pi plans [message #62212 is a reply to message #62211] Sun, 28 March 2010 23:45 Go to previous messageGo to next message
Thanks, interesting. Now you've given me something else to think about. I'll have to model it in hornresp when I can get my other computer going. With the alpha connected direct to the amp, a 200 watt per channel kenwood, it should get plenty loud.
Re: 8 pi plans [message #62240 is a reply to message #61795] Wed, 31 March 2010 22:17 Go to previous messageGo to next message
Cheesehead is currently offline  Cheesehead
I'm interested in the 8pi plans as well. Do you think that the speaker could perhaps be converted to a "double 8pi", with a second midwoofer horn mounted upside-down on top of the first, for greater power handling? Also, I'm a bit confused - is this speaker meant for corner-loaded or freestanding use?
Re: 8 pi plans [message #62244 is a reply to message #62240] Thu, 01 April 2010 09:45 Go to previous message
The eight π loudspeaker can be used in a corner but doesn't need to be put there. If you have the right corners, put them there, like π cornerhorns. But if not, just angle them inward like three π or four π speakers.
Previous Topic: 4 Pi build for HT
Next Topic: Just scored a pair of 3pi speakers!
Current Time: Wed Jun 10 05:03:50 CDT 2026
