Home » Audio » Source » ART DI/O mods?
ART DI/O mods? [message #14044] Mon, 08 December 2003 23:53 Go to next message
This single tube dac is great but I would like to take some of the gain out of it. It's just really a hot signal. Any one have any mods for the home workbench?
Bill
Re: ART DI/O mods? [message #14045 is a reply to message #14044] Wed, 10 December 2003 19:36 Go to previous messageGo to next message
Is this an Art Audio product? What features does this unit have, or is it purely an interface?
I'm kind of surprised Dave didn't reply, because I think this is one of his things. But maybe not.
Re: ART DI/O mods? [message #14046 is a reply to message #14045] Fri, 12 December 2003 23:51 Go to previous messageGo to next message
Hi Wayne,
It's a small single tube DAC. You can take the digital signal from any crappy sounding cd player and just use it as a transport. Then the DAC sends analogue signal into your preamp. I've heard better transports and dac before but the increase in performance was small and they cost literally thousand's. The DI/O is around a hundred bucks.
Anyway the problem if it has one is that it's suited for balanced line and the signal is pretty hot. I'm more than happy to take it apart and replace some parts. I'm just not the guy to re-engineer the thing! Pick one up, they're cheap, you'll love it.
Bill
Re: ART DI/O mods? [message #14047 is a reply to message #14046] Sat, 13 December 2003 00:11 Go to previous messageGo to next message
The simplest D/A convertors are just a bank of resistors, and this method works pretty well, actually. A parallel set of digital signals is sent from the buss at periodic intervals, the sampling rate. All lines from the most-significant bit down to the least-significant bit are tied to a common point through resistors and, voila! The result is an analog signal. This is then amplified, and from what you're telling me, this is done by a small signal triode in your player.
What brand is your interface or kit? What I mean is, who provided it? Do you send off your existing CD player for modification? Or do they sell the interface outright? Do you buy the CD player with the summing tube already installed, as if it were made that way from the OEM?
Re: ART DI/O mods? [message #14048 is a reply to message #14047] Sat, 13 December 2003 20:12 Go to previous messageGo to next message
Hi Wayne,
I just copied the info from the ART website. You can find these little guys at almost any music store. Local or online. They do a great job compared to most things I've listened too, and for the cost of this unit there isn't anything that competes.
All you need a a CD player that has a digital output (coax only) Plug the coax into the dac, then plug the right and left output from the dac into your preamp or receiver. Now your cd player is just a transport and the DI/O is doing all the work.
Some how me putting together a bank of resisters isnt going t6o sound as good or be as cost effective in the end!
Bill
DIO - A/D Converter Overview
Designed to help ease the transition to the digital world, the DIO offers high resolution stereo 24-bit A/D-D/A conversion at switchable sample rates from 44.1 to 96kHz. In external sync mode, the DIO’s intelligent synchronization allows for automatic sync with outboard equipment at sample rates from 22kHz to 100kHz.
The DIO can be used in a wide variety of applications including recording, project, and home studios. Let the DIO be the interface for your “classic” analog signal processing gear in an all-digital production environment. It’s the perfect interface for any digital workstation or computer based recording system and gets the A/D-D/A conversion process out of the noisy digital environment.
You can use the DIO as your instrument’s direct-to-digital interface, thanks to its high input impedance. Upgrade the A/D-D/As on your DAT machine or any older digital I/O equipment with the DIO’s high resolution converters. Get the most out of your dynamic range on new samples and overdubs. You can even loop thru the DIO to add “analog” warmth and musicality to an existing digital track.
The latest refinements in ART’s award winning tube pre-amp design are integrated on the front end, before the A/D converter, for analog gain and dynamic range control. At the clean setting, the tube circuitry is virtually bypassed and the A/D sees a “straight wire with gain” signal. As you increase the control the signal goes from ultra clean and transparent, thru silky, to smooth, to warm, to fat. At this end the tube becomes the dominant gain element, enhancing lower and mid level signals and soft limiting peaks and overshoots before they hit the A/D.
This stereo unit provides superior audio conversion in the same compact package as ART’s famous TubeMP, and like the TubeMP, the DIO’s performance exceeds that of units costing many times its price. It’s unique combination of features and flexibility will make it a must-have in any audio toolkit.
DIO - A/D Converter Features
SWITCHABLE 44.1, 48, 88.2, AND 96kHz SAMPLE RATES
INTELLIGENT SYNC COVERS A WIDE EXTERNAL RANGE
1/4” STEREO ANALOG INPUTS AND OUTPUTS
VARIABLE INPUT GAIN
HAND-SELECTED DUAL TRIODE TUBE
TOTALLY VARIABLE TUBE CHARACTER FROM TRANSPARENT TO WARM
Re: ART DI/O mods? [message #14049 is a reply to message #14048] Sat, 13 December 2003 20:40 Go to previous messageGo to next message
Gotcha - Thanks for the "heads up." I didn't know if this was something you purchased as a stand alone unit, or if you sent your player in to someone for modification. Thanks for lettin' me know!
Re: ART DI/O mods? [message #14050 is a reply to message #14048] Wed, 17 December 2003 21:29 Go to previous messageGo to next message
brianjones is currently offline  brianjones
I don't have a pre-amp, could I hook it up directly to my power amp?
Re: ART DI/O mods? [message #14051 is a reply to message #14050] Wed, 17 December 2003 22:30 Go to previous messageGo to next message
Sorry but not even a remote chance the signal is very strong. If your cd player has a variable output it would work. I think you would be better off with a two channel 100k pot after the DI/O. A stepped attenuator would be very nice. There is a lot of signal and any form of passive preamp would do the trick.
ART DI/O mods FAQ [message #14052 is a reply to message #14044] Thu, 18 December 2003 11:46 Go to previous messageGo to next message
Wayne1 is currently offline  Wayne1
Craig Fraser has had a site with lots of different mods listed for a couple of years now.
I have been modding this unit for about that long.
There are lots of things you can do to improve the sound of it.
Check out Craig's site and if you have any questions drop me an e-mail
What's the latest on power supplies? [message #14053 is a reply to message #14052] Thu, 18 December 2003 12:29 Go to previous messageGo to previous message
Jim D. is currently offline  Jim D.
I have a couple of highly modded ART DIOs. What's the latest for PS upgrades (DIY of course) after the Stancore walwart?
Thanks,
Jim D.
Previous Topic: Marantz TT320 turntable info needed
Next Topic: Denon DP-25F belt fell off, help!
Current Time: Sat Jun 01 03:50:49 CDT 2024
