Home » Sponsored » Pi Speakers » My 4 Pi Build
Re: My 4 Pi Build [message #97074 is a reply to message #97073] Mon, 16 October 2023 14:04 Go to previous message
Unity_Coupled wrote on Mon, 16 October 2023 13:15
Potentially there's another issue, this one not so easy (or cheap) to resolve. I suspected from the get-go that at least one of my drivers was reconed, due to the over-application of glue around the dust cap on one of the cones, and the absence of a part number stamped on the backsides.
Compared to the JBL data, the impedance is not as smooth above 500hz, but it doesn't seem particularly bad either. As you've said in another post, the impedance notch at around 1k is a good indicator that the cone is aftermarket.
I'm going to wait until I can conduct final FR measurements and listening tests before making any decisions. I paid about $300 for both drivers, and if they're good enough I'm inclined to keep using them.
I would do the same thing. Measure the response to know for sure.
Even if it's not, a recone isn't too expensive and will make the driver 100% good as new. That's one of the really great things about the 2226H driver.
Previous Topic: Heat sink, Heat exchange for driver/cabinet
Next Topic: Five 2226s are here!
Current Time: Sun Jun 02 13:08:01 CDT 2024
