Home » Sponsored » Pi Speakers » Subs for floorstander and corner horns
Re: Subs for floorstander and corner horns [message #96494 is a reply to message #96427] Fri, 10 March 2023 07:30 Go to previous message
Ybolg is currently offline  Ybolg
Wayne,
Thanks for the details! It's frustrating that none of these speaker spec sheets list flange thickness.
That kind of makes things easy for the LAB12 since your spec baffle thickness is 18mm. I can just cut out the recess OD, and glue in a 13.5"OD 11"ID backing ring behind it to mount the speaker on.
Plunge router and circle jig is too much fun. Right now I'm waiting on some new baffles for my 2pi floorstanders after I ruined a pair trying to cut them without the proper tools (using the scrap for backing rings). Figured I'd use up the rest of the sheet with some sub cabinets.
Previous Topic: Pi Three and Pi Four Speaker Plans?
Next Topic: Pi3 vs Pi4
Current Time: Sun Jun 02 04:49:14 CDT 2024
