Wayne Parham Messages: 18700 Registered: January 2001
I'll send plans via email.
I would suggest swapping the midwoofer, then the tweeter compression driver and then the crossover board. Make sure you are focused on the right thing.
If it turns out it's the crossover, I'd replace the resistors first, followed by the capacitors. I can't imagine the coils going bad but if all else fails, I guess you could try swapping them too. But I'm sure you will have found your culprit long before you get to that point.
