Home » Audio » Thermionic Emissions » Budget Amp
Re: Budget Amp [message #9144 is a reply to message #9125] Wed, 03 August 2005 00:48 Go to previous messageGo to previous message
metasonix is currently offline  metasonix
in my experience, these Chinese amps usually sound really good. AND are a great bargain. If I were Audio Research or Conrad-Johnson I'd be worried.
one thing, though--I've had quite a few of these things brought to me after the importer or mfr. disappeared. Usually the power transformer died, or there was heat damage due to something burning up on the PC board.
so, if you want your tube amp to last, take some free advice--KEEP IT COOL. Point a fan at it and live with the noise. The amp will last longer.
Previous Topic: Finally, SET Amps That Will Rock The House
Next Topic: Pull pin...
Current Time: Thu May 23 00:57:10 CDT 2024
