Home » Audio » Thermionic Emissions » Tono Preamp
Absolute Polarity (Phase) [message #8958 is a reply to message #8953] Sun, 15 May 2005 00:49 Go to previous messageGo to previous message
Triode_Kingdom is currently offline  Triode_Kingdom
It was interesting to see a mention of this in the manual. And you're absolutely right, phase (polarity) is not always maintained during recording. In fact, because I nearly always test my new amp/preamp designs in mono, I am painfully aware of just how bad the situation is. Typically, when testing/tweaking new designs, I add both channels of the source (usually CD) through resistors in order to capture all the music. However, I have several CDs for which this technique cannot be used. One example is a Yardbirds CD that appears to have been recorded with the L and R channels exactly 180 degrees out of phase. Either channel alone sounds fine, but when mixed, total output amplitude decreases about 9-10 dB. Several other discs suffer from audible frequency response anomalies when the channels are mixed into mono. This usually manifests itself as a significant reduction of high frequency content. When listening to a particular Steve Miller CD for example, everything above 5 kHz or so virtually disappears when the channels are combined.
These defects are more difficult to detect when stereo transducers are used, because cancellation from out-of-phase signals is incomplete (or in the case of headphones, nonexistent). Nevertheless, this issue points out how poorly source material is being produced and processed these days, and how important it is to select programming carefully when evaluating a system.
Sorry, I know this doesn't have much to do with the preamp under discussion, it just caught my attention.
Previous Topic: High Power Output SET
Next Topic: Air Dialectric caps
Current Time: Tue Jun 04 16:13:50 CDT 2024
