Home » Audio » Thermionic Emissions » I'm Back.
Re: I'm Back. [message #8801 is a reply to message #8800] Mon, 31 January 2005 20:31 Go to previous messageGo to previous message
Ok...a bit at a time. There is a block in PSUD in thecapacitor specifications window( highlight the cap, right click and left click the 'Edit' box ). I only mentioned it as a semi-unimportant piece of input data.
I appreciate your asking little questions about details which are not spelled out adequately. I will share my design considerations and trade-offs as requested. Of ocurse, if I am guessing out of my butt, I will also tell you of this. I do try to keep it to a minimum.
For the DC filament supply, you can filter and drop voltage through a few resistors, or regulate with something like an LM317. I learned obout those things with Google and the diagrams proviede on the packaging Radio Shack sold them in.
After a bit of wrestling with the unregulated stuff I am using in the new one, I do miss the adjustability of an LM317 with a pot in its voltage setting circuit. I also remember making a few mistakes with the first building with the LM317...so I suppose there is no free lunch, just different lines at the same register. We'll get there together, I'm sure of it. Especially if you keep asking questions.
regards,
Douglas
Previous Topic: Proud Papa Syndrome (Check out my new amp...)
Next Topic: PSUD/switchercad
Current Time: Mon Jun 03 19:11:53 CDT 2024
