gofar99 Messages: 1916 Registered: May 2010 Location: Southern Arizona
Hi, if you want to go cheap you can use an external drive with nothing more than the right type of cable. SATA3 drives get both signal and power through the cable. External back up drives often use only a SATA2 cable and if you go solid state there are ones of both types (they just cost more).
