Home » Audio » Thermionic Emissions » rectifier controversy
Re: rectifier controversy [message #8400 is a reply to message #8388] Sun, 08 August 2004 15:43 Go to previous message
metasonix is currently offline  metasonix
Yes, it is contingent on design. The main disadvange to cheap
silicon rectifiers is their slow switch-off delay, which causes a
big peak current to be drawn for a very short time. This can
result in added "hash" noise in the circuit, esp.
if the circuit grounding and wiring arrangement isn't optimal
(as in, rigid star grounding, component layout etc).
FREDs and tube rectifiers don't have so much of this problem,
thus are less prone to putting "hash" into the circuit.
Also, tube rectifiers have the slow warmup built-in,
always a good thing to use to prevent possible cathode stripping
in power tubes. A well-designed amp would optimize layout and DC
supply filtering to use silicon rectifiers properly, so it's often
a wash as to which is "superior" to the others.
Now, if you're a hobbyist building your own tube amp, and you don't
have lots of time to sit and build multiple revisions of the chassis
and test each one for noise floor, a tube rectifier is handy. If
you want a recommendation for a DIY amp, I'd say use damper diodes--
they are extra-rugged and usually have very slow warmup.
Previous Topic: Canary Audio
Next Topic: ASL Tulip amp mods
Current Time: Thu Jun 06 22:13:01 CDT 2024
