Home » Audio » Speaker » Mono "flanking sub"
Re: Mono "flanking sub" [message #83004 is a reply to message #81624] Thu, 14 July 2016 12:39 Go to previous messageGo to previous message
jonone is currently offline  jonone
Ok thanks Wayne, I might try and make them so there down firing for now but can be forward firing in the future when the children are bigger.
The speakers are close to the rear walls on brackets and the flanking subs will be directly below them, (the only space I have)so not in your recommended positions, so they should definitely help with the notch caused by the floor but maybe not much for the side or rear reflections? but having the mains so close to the rear should help with that reflection anyway?
Would you expect to see a improvement in the response by adding the second flanking sub over the single?
Previous Topic: Interconnect cables
Next Topic: Class d for flanking subs
Current Time: Fri Jun 07 17:07:26 CDT 2024
