Re: 4 Pi Build Progress [message #81600 is a reply to message #81462] Sat, 26 September 2015 08:39 Go to previous messageGo to previous message
Irrespective of the anomalous frequency shift Wayne mentioned, the only time I have gotten issues like this was when I was running both speakers simultaneously and taking measurements. The only way that works is if the microphone is just about exactly between the monitors. As you've stated, your microphone was significantly off. Do you think it was possible you had both running, or one only partially reduced in volume? In my attempts to center the mic I found that the further off center, the lower the frequency of cancellation. This may not be your problem but check it if you haven't.
Next Topic: Implementation
Current Time: Thu May 23 17:33:30 CDT 2024
