Re: 4 Pi Build Progress [message #81465 is a reply to message #81462] Mon, 20 July 2015 12:10 Go to previous messageGo to previous message
Made some more progress yesterday after going to homedepot to pick up the rest of the MDF. Sadly their panel cutter wasn't working so i ending up having to get 14 2ft x 4ft MDF boards, which was good and bad, Good because it fit in my car and on my small table saw, Bad because i didn't get to use my cut sheet which would have made all the cutting much easier if i could have started with 25" wide sheets not 24"
4pi cut sheet"
index.php?t=getfile&id=1764&private=0
3 pi Subwoofer cut sheet:
index.php?t=getfile&id=1765&private=0
Finished all the major cuts for L C R and 2 flanking subs.
index.php?t=getfile&id=1763&private=0
Panels with bracing, The bracing is glued and pined down using an 18gaugae pin gun with 1 1/4" pins. I used this same method to put together the ports, I'll be gluing and clamping everything together from this point.
index.php?t=getfile&id=1761&private=0
needed to finish 3 4pi's and 2 3pi subwoofers.
Here's a dry fit with all the side bracing in place, will had cross support above the woofer when its all together.
index.php?t=getfile&id=1762&private=0
Next Topic: Implementation
Current Time: Thu May 23 15:41:19 CDT 2024
