gofar99 Messages: 1911 Registered: May 2010 Location: Southern Arizona
Hi....sounds dumb, but check for the fuse in the fuse box. There also could be one in line. Another easy thing is to check that the connectors on the rear of the radio are connected. Once in a while one will work loose. If all else fails new ones are likely better and are not too expensive. Many shops will install them for free or nearly nothing.
