gofar99 Messages: 1912 Registered: May 2010 Location: Southern Arizona
Hi, Yes I have. However while some folks claim they are magical, I find them to be pretty much identical to ones with well thought out power supplies. The claims are mostly for quieter or if you use the term blacker background and better clarity. I keep a version of the IC based phono/tape preamp around that uses a pair of 9 volt batteries. Current drain is just under 10ma. It is handy to use as a test device. When compared side by side with the one just like it that uses an AC power supply I can not tell them apart. Both spec out at about -100dbv in MM/MI and -95dbv in LOMC/NAB. The noise spectrum is virtually identical. All that said....if battery powered gear is what you like, so be it I have no beef with it. Just not my thing.
