Home » Sponsored » Pi Speakers » Pi 3 subwoofer
Re: Pi 3 subwoofer [message #73263 is a reply to message #73228] Thu, 12 July 2012 18:30 Go to previous messageGo to previous message
48h350 is currently offline  48h350
Hi Wayne I am following the road of using Pialign to model the enclosure of the above mentioned driver jbl gto1214.
(Thiele and Small parameters attached in original post)
after a while I "think" I understand how to use it. Can I confirm with you that, to get QD for your program, you do: Qd= 1/Qm + 1/Qe ?
where Qm is Mechanical Q of the driver and Qe is the electrical Q.
I obtained a Qd of 2.133
I attach the results, can you be so kind to see if they make sense?
For the dimensions, am I right to assume that volume HAS to be reached with the suggested dimension in relation with the port diameter and length ? In other words if I wanted a square faced SW, is there any way to "lead" the program to do so ?
Thanks Wayne
massimo
  • Attachment: JBL GTO1.PID
    (Size: 0.68KB, Downloaded 245 times)
Previous Topic: 4pi plans
Next Topic: Pi7 Mid Horn Question's
Current Time: Wed Jun 12 08:54:17 CDT 2024
