Re: IR Remote Control [message #73151 is a reply to message #73063] Thu, 28 June 2012 05:53 Go to previous messageGo to previous message
Wayne Parham wrote on Wed, 20 June 2012 20:12
Maybe a proud papa thing, but it's the best "preamp" I've ever owned. I sold all my other preamps, resistor passives, LDR passives, solid state actives and tube actives. Now I just run RDACs for volume control.
Madness! No tubes? No mechanical switches? The horror!
Somewhere in the correspondence over the build and receiving packages from Digikey I was inspired to get the UPS damaged Aikido off the shelf and do the re-build. I drilled and painted the replacement chassis over 2 years ago and then forgot about it.
Now I just have to wire up the switch and attenuator and it's done. Then, with a little help on the power supply and layout from you guys, I'll do the RDAC and have a Rodeo.
index.php?t=getfile&id=805&private=0
Current Time: Thu Jun 06 11:00:23 CDT 2024
