gofar99 Messages: 1916 Registered: May 2010 Location: Southern Arizona
From a marketing view I suspect there will be something higher. They did try 3d and so far it is a non-starter. A significant problem with be resistance from cable companies. More resolution means more bandwidth and I am sure they don't want to go to the expense if they can fleece us just fine now. Some don't even do the 1080 as is. I find that the 1080 is really just fine on out 55 incher. More would probably not make a difference. There is a problem with source material as well. I'm sure some is done in higher resolutions, but a lot is not. Conversion from older film is likely to not be any higher either.
