Home » Audio » Silicon Valley » Which is Better, Tube Amps or Solid-State Amps? (a discussion on the ideals of each type of amplifier)
Re: Which Is Better, Tube Amps or Solid-State Amps? [message #66596 is a reply to message #65629] |
Wed, 09 March 2011 16:24 |
AudioFred
Messages: 377 Registered: May 2009 Location: Houston
Illuminati (1st Degree) |
I'm fully converted to solid state. The overwhelming disadvantage of tubes in in the cost. You can buy a new 50 watt/ch solid state integrated (NAD, Cambridge Audio, etc.) for about $500 msrp. The equivalent 50 watt/ch tube amp, with high quality transformers, etc, sells for about $1,500-$2,000. You can get a no-name Chinese amp on Ebay for less, but there will be quality control issues.
The second disadvantage is in a tube amp's reliability. Power tubes blow, and they usually take a cathode bias resistor with them, so you're looking at a repair job. I have four high quality tube amps, and right now two are out of service.
There was a time when budget priced solid state equipment sounded harsh and grainy compared to tube equipment. Solid state has improved quite a bit in the last ten years, and that $500 fifty watt amps sounds pretty good. In an effort to gain some "tube warmth" I added a tube buffer to the system that includes a $170 Oppo player and a $500 Cambridge Audio Azur integrated. I gained a very slight warmth but lost a very slight amount of resolution, and decided I prefer the system without the extra component in the signal path.
By: woodfree on Thu, 23 December 2010 22:54
By: Adveser on Fri, 24 December 2010 04:54
By: Aki on Wed, 29 December 2010 18:25
By: Adveser on Wed, 29 December 2010 19:08
By: Shane on Fri, 07 January 2011 10:24
By: Adveser on Fri, 07 January 2011 12:04
By: Shane on Fri, 07 January 2011 12:08
By: steve f on Mon, 28 March 2011 13:38
Difference Between Solid State Amp and Vacuum Tube Amp
By: Hannah on Tue, 23 August 2011 02:11
Re: Which is Better, Tube Amps or Solid-State Amps?
By: gofar99 on Sun, 01 October 2017 16:39
By: Rusty on Fri, 22 June 2018 09:47
Current Time: Tue Jun 11 10:01:32 CDT 2024
