Home » Sponsored » Pi Speakers » Imaging, placement and orientation
Re: Imaging, placement and orientation [message #53035 is a reply to message #53033] Sat, 03 January 2009 15:14 Go to previous messageGo to previous message
LAL is currently offline  LAL
I can attest to this. I have been using my Stage 4's temporarily for L & R speakers in a home theater set up. Set up as you recommend(and with no center channel speaker) the image is locked in at the TV set. I can slide from side to side with little or no effect on the stability of the image. The phantom center image is now so good that for the first time I am questioning the need for center channel speaker. Given this plus their dynamic range I think you would be hard pressed to find many speakers that would work better for home theater applications.
LAL
Previous Topic: Highly Technical Question: Where do the Pi Stickers Go?
Next Topic: Floor Bounce ?
Current Time: Fri Jun 07 12:11:00 CDT 2024
