Sponsored
Gaskets
Gaskets
message #51946
Fri, 28 March 2008 20:30
January 2001
The PVC plastic used to make shower pans makes a great gasket material. Cardboard works pretty well too.
It's easy to make gaskets. Just draw an outline of the part with a pen, and also make a mark where mounting holes are.
Drawing an outline of the crossover PCB to make a gasket
Next, cut the gasket out and make holes for screws with a hole punch.
Cutting out a gasket
You can make gaskets for drivers, horns, crossover PCB's, Zobel resistors, access panels, whatever you need. It is very easy to do.
Gasket set for a four
π
loudspeaker
Message index
Gaskets
By:
on Fri, 28 March 2008 20:30
Re: nice looking xover!
By:
Matts
on Fri, 28 March 2008 23:12
By:
on Sat, 29 March 2008 00:33
Re: Gaskets
By:
Shane
on Sat, 29 March 2008 00:12
Re: Gaskets
By:
on Sat, 29 March 2008 00:35
Re: Gaskets
By:
Bill Epstein
on Sun, 30 March 2008 04:23
Re: Gaskets
By:
on Sun, 30 March 2008 22:37
wood horn
No size limit on HT subwoofer, help please
Tue Jun 04 08:34:10 CDT 2024
