Sponsored
insulation thickness
Re: How do you measure the FB
message #37841
is a reply to
message #37829
Fri, 16 August 2002 13:54
bmar
May 2009
How can you measure the box frequency after the box is built?
to check and make sure your port and insulation did what you planned
Bill
Message index
By:
replay
on Fri, 16 August 2002 06:52
in a small enclosure
By:
Sam P.
on Fri, 16 August 2002 08:50
By:
bmar
on Fri, 16 August 2002 13:54
Measure impedance
By:
on Fri, 16 August 2002 16:34
you can obtain Fo by blocking the port(s)
By:
Sam P.
on Sat, 17 August 2002 07:12
Corner Horn Question
T-nuts question
Fri Jun 07 08:19:22 CDT 2024
