Home » Sponsored » Pi Speakers » Just bought pre-cut MDF for my One Pi speakers!
Re: Port stuff [message #37377 is a reply to message #37376] Thu, 18 July 2002 12:09 Go to previous messageGo to previous message
If you can get 59.2mm ports, that's perfect. It's only 0.05" different than what is specified, which is closer tolerance than I would expect when buying cardboard tubes of the exact dimension.
About the paint we apply to the inside of the ports, they're hand-painted after the veneer is applied so that the edge of the veneer is covered. Not the most time-effective way to do it, but the results are good.
Previous Topic: Sensitivity ratings for Delta 15 etc
Next Topic: wall lining in two Pis
Current Time: Mon Jun 17 18:59:28 CDT 2024
