Home » Sponsored » Pi Speakers » 4 pi series/ parallel resistor headache
four 64 ohm resistors in parallel [message #35069 is a reply to message #35067] Sun, 10 February 2002 10:56 Go to previous messageGo to previous message
will also equal 16 ohms, Yep, if you are using regular wirewound power resistors, vs. the NON INDUCTIVE mills brand he mentioned. Building a 16 ohm part with the values available means they need to use the four 16 ohm ones, arranged as specified previously.
resistors in series
Rt = R1 + R2 + R3+...
1/Rt = 1/R1 + 1/R2 +...
Hope the formulas make this clearer. Sam
Previous Topic: The Theater 4 Pi's WORK!!!
Next Topic: true readings of power,and false readings
Current Time: Tue Jun 18 10:56:23 CDT 2024
