Home » Sponsored » Pi Speakers » PiAlign questions: ideal vs enclosure Q (and Kappa15LF looks sweet!)
Re: Which graph to trust? [message #34279 is a reply to message #34278] Wed, 28 November 2001 09:47 Go to previous messageGo to previous message
Colin Fritzke is currently offline  Colin Fritzke
Trust the chart on my webpage. I was very much into going with the Kappa 15LF for the same reasons you suggested, but upon closer inspection of an actual FR plot, I decided against it because there is no way Wayne's standard Four Pi Crossover will deal with those peaks at 1.7K and 2K. They could be tamed, but that would require some drastic measures and I have neither the tools nor the patience to do it. Eminence sensitivity specs are high because they rate the sensitivity of their drivers at 1kHz.
Wanna get some Kilomax 15's? I know of a source that can get them for not too much more than you'd pay for the Kappas....
Colin
Previous Topic: closed vs. vented sub-woofer box
Next Topic: Replay.. check your e-mail
Current Time: Sun Jun 16 15:32:05 CDT 2024
