Home » Audio » Craftsmen » Anyone using biscuits when building speakers?
Re: Anyone using biscuits when building speakers? [message #29958 is a reply to message #29909] Thu, 27 December 2007 15:53 Go to previous message
Jeffery L is currently offline  Jeffery L
I am a of rabbet and dado joints. They will line everything up for you.
I would also say it depends a lot on the type of wood you are gluing. Every wood holds glue differently and in each circumstance the strength of a butt joint will differ.
I had an old box made from MDF using only glue, rabbet and dado joints. When it had served me well I decide to give it the old sledge-O-matic treatment and the joints never gave, the box did have a lot of 6" holes in it though.
Previous Topic: Newbee Tools
Next Topic: polyfill blues
Current Time: Mon Jun 17 11:48:40 CDT 2024
