Home » Audio » Craftsmen » Back to square one, so to speak
Re: Hey Bill, can you just cut a slot? [message #29245 is a reply to message #29242] Tue, 31 August 2004 06:24 Go to previous messageGo to previous message
A slot is acoustically better than holes since it minimizes the distance between the drivers; the trick would lie in making the whole thing airtight. Also, a straight slot could cause problems with the mounting screws depending on the particular driver frame configuration. I went with holes to maintain structural integrity and keep things simple.
Previous Topic: Other plywood tricks
Next Topic: No table saw? No problem - build a sawboard
Current Time: Wed Jun 12 06:46:41 CDT 2024
