Home » Audio » Craftsmen » How Thick is Thick Enough?
One half inch. [message #29133 is a reply to message #29131] Tue, 29 June 2004 14:30 Go to previous messageGo to previous message
If you do it right, that is. I build all my prosound cabs from 1/2" plywood- or thinner for curved parts- and they don't vibrate because they are properly braced. Panel to panel cross bracing is no less than 4 times as effective pound for pound as sheer panel mass in controlling vibration. For home use where portability is les of a concern 3/4" ply or MDF is fine, but crossbracing is still the key. If you have no unbraced panel wider than 6 inches the box will not vibrate.
Previous Topic: So you want to move the volume pot to the rear?
Next Topic: Modular Speakers
Current Time: Wed Jun 12 21:16:53 CDT 2024
